HOLY JEEZ!!! I drove it!
My God.....
It absolutely smokes the tires in second gear just taking off!
Forget first- its a total waste of time...
I am going to be easy on it until after dyno day!
Whats the most amazing is the temps!!! The damn thing runs head temps at 275-310 and is dead even left and right! Oil has yet to hit 190!!!!
I never dreamed that the temps would be this good with a 10:1 3 liter engine! The heads lack some fins, but i swear its not making a difference at all! The pressure within the upper plenums of the shroud is the highest I have ever seen and that is really shoving air through the fins on the biggest Nickies in the world!
I have yet to take it over 4K- You simply don't need to... Its like driving a Big Block chevy...... Smooth as silk, power from idle and sounds 100% stock.
We made it happen and I'm amazed.
- Smacktalkinorange
- Plastermaster
Racer Chris
Just took it on a 20 mile trip...
It is absolutely unreal how cool it runs!
This damn thing runs cooler than my Bus , but not quite as col as the 912E- BUT this engines is 1000 cc bigger with way less cooling fins!
Oil temps run about 180 with just a small mesa cooler as an external and the DTM!
With the 2332 TI in the same car I was running head temps almost 100 degrees more than this baby!
I got my bad Dell back from Art Thraen today and installed it. I believe it was a mistake because I did not have those carbs on for the dyno work.......I need to do some tuning tomorrow before I leave with the LM-1 and get it a tad better than it is now... seems to run out in the midrange just about peak torque..
What a smooth driving, cool running animal!
This development was for more than just power- The temps these heads run is absolutely amazing... A true testament to the DTM!
- DudeAndHisBus
Guest
Re: HOLY JEEZ!!! I drove it!
Jake,MASSIVE TYPE IV wrote:My God.....
A 3.44 would spread that out quite a bit and also eliminate the need for
larger carbs!
I mean, if your bug can do 140MPH at 5000 RPM, who needs to go faster?
OF course, a 3.44 won't work with that Quaife differential.......you DO
have a Quaife in there ,DON'T you? IF you don't, you may find that
you're gonna NEED one!
Don
bayareathrasher
