911 6 to VW trans?
Max keltvik
911 6 to VW trans?
How to bolt a Porsche 2.4l -73 in to a t-1 trans?
No idea. Suspect machining on the porsche flywheel would likely be required, or at least the ring gear cut back.
IIRC the TO pad on the PP is in virtually the same place.
(Ring gear really only needs to be 1/4" wide)
Ring gear is std 12v ACVW.
You would have to use a 71> tranny with the guide tube for the TO bearing, or with the press in aftermarket one on the early trannies
The Porsche 901 can be made to fit without too much pain.
Looking for a wild Baja?
