Cryogenic Treatment
michaelmoo
Cryogenic Treatment
Jake.
I know that your kits are designed to work together. I was wondering what you thought of the cryogenic treatment. I read that some of your engines have had the treatment done. I?m looking at a 914 2270 kit (with KitCarlsen FI) for this fall and wondered what you thought about it on this kit. What would that do to the option of Balance Rotating Assembly and Pre-prepare Engine Kit Assembly? The car would be a street only car.
Thanks,
Mike
Thanks,
Mike
Mike, Since we have taken the customization away from engine kits cryo treatment is NOT an option any longer on kits and or individual parts.
The process slows down the prep time for the kits and speed and more volume is the ONLY way we have been able to drop the kit prices so drastically.
ALL my Turnkey engines receive Cry enhancement. I have seen the huge benefits from it and thats why we treat every engine that leaves the dyno with it. If the process wasn't so detailed and expensive the kits would also receive it...
we have a long enough backlog on complete engines to allow for the cryo option and not effect our delivery times.
The store has been such a success that we are having an issue just keeping parts on the shelves to fill orders with... I make up 10 of something and the next day we are backordered for two more than that....... Its a good problem to have!
4getaboutit
Its more than simple "freezing"... Different metallurgy effects the temperature the parts are taken down to and the rate they are taken there as well as the rate they are brought back to room temp..
Its called "Custom Thermal Cycling" for a good reason. The guys that I work with have created an entire program just for the aircooled engine and more specifically the Type 4 engine.... They have been doing this with me for 5 years now and we have conquered a lot of challenges with diffferent profiles.
You could send them the entire "Kit" or have me ship it to them when its completed and then deal with them directly.. Their website is www.percryo.com
- dstar
Valve springs too?
THey ahve very good pricing!
http://www.percryo.com/lg_eng_pricing.htm
I think I'm gonna send my cam to them, it is an EP......and I'll be using HEAVY Johnsons.
Don
Don
Guest
- raygreenwood
Ok....Jake....always the one to open the can of worms
But...I am building my own engine, but will be ordering cam, lifters, bearings and oil pump from you. Possibly springs and a few nick knacks as well.
Suppose....I got all of those parts in from you, dropped it into a box with my finished/balanced crank and rods.....and sent it to your cryo guys. Wherin...without giving me a single piece of info to me.....they cryo my parts to your specs.....but do not proceed....until they recieve e-mail or phone from you or Cathy....saying that you have recieved.....a "royalty" check (of sorts)...from me. After all, they...plus you.... did the research. But, they would get paid for the labor/service on the parts....you would get a royalty for an investment of your brain work....and never have to touch the stuff...or break into your busy production schedule.
Your thoughts please. Ray
vrsechslvr
Cryo does not physically change components. No need to rebalance after the process, BUT don't try any machining after the process because it is much more difficult.
Yes, we cryo heads but they must be done with all guides, seats and etc removed. It increases the thermal conductivity of the head allowing heat to move faster into the cooling air stream..
I have cryoed cases to "Age" them but never did it to customer's engines... Just test and full race stuff.
- raygreenwood
That better heat conductivity interests me. I wasspeculating on having my heads hard anodized black....all external surfaces only. Comustion chambers, intake and exhaust tracts and rocker boxes would be masked. That alone...will draw signifcant heat from insideto the outside. Have you ever tried that Jake? Ray
