Compression Ratio (static / dynamic) and more calculator
- 914fan
I have compiled and built a excel sheet that calculates your compression and other values. I would like to post it here for everybody to use. I feel that is would be a good tool for building and dreaming up your next engine. I cannot guarantee its accuracy but can say that it is within the range of answers most on-line calculators provide. This would be a good guideline but I will recommend doing the math yourself or double-checking with other calculators.
**I accept no responsibility for any damage caused by using this sheet.**
Having said that can someone tell me how to post it?
- tuna
Send it to me via email and I will host it on my website.
Tuna
Tuna
http://vdubgeek.blogspot.com/
Type 4: Secrets Revealed - https://type4secrets.blogspot.com/
Tom's Type 4 Corner - coming soon!
EMPI Imp Homepage - coming soon!
My VWs - http://vdubgeek.blogspot.com/p/my-vdubs_5.html
- tuna
Here's the calculator. It looks pretty good and I'm sure I'm going to lose many hours of my life playing with it.
Tuna
Tuna
- 914fan
914fan.
Dstar
On the calculators I looked at the only cam info they wanted was intake closed at X. I do not know if there are more variables involved. If there are and someone can tell me how they are involved and I will try to incorporate them.
I was under the impression that dynamic compression was basically the same as static except that your stroke was what ever was left when the intake closed.
I could be wrong.
Let me know what you think. I would like to provide the best sheet I can. It helps me as well as you to have correct data.
Feel free to modify the sheet to suit your needs.
I could be wrong.
Guest
HAM Inc
This will come in handy! Thanks for the effort.
As for dynamic compression that's another matter. The intake valve actually closes as the piston is on the way up the cylinder on the compression stroke. Determining dynamic compression is trickier than just calculating the cylinder volume when the intake closes and using that measure for swept volume. Overlap won't figure into this calculation.
Dynamic compression is also going to encompass the volume of air that ACTUALLY flows into the cylinder. (Overlap can effect this) This will vary with RPM's. It would take a very sophisticated program to accurately calculate dynamic compression, and the input data would have to include intake flow data, rod/stroke ratio, and a host of other info. plus the many intangibles that come into play when the engine is running that effect cylinder filling.
The truth is actuall dynamic #'s would be meaningless (at least to me) until performance trends were estasblished relating to different values. Two engines with identical displacement and chamber volumes will have radically different dynamic ratios if the heads flow #'s are different and/or intake valve closing specs are different.
FYI the intake valve closing event is the most important of the valve events.
- dstar
HAM Inc wrote:FYI the intake valve closing event is the most important of the valve events.
*efficient*, i.e. make more power, if the intake valve closed right
@ BDC of the intake phase, instead of a few degrees after??
I'm trying to figure out the best *clock* to install my Annihilator
cam that I bought from Jake.
Don
- speedy57tub
