alternator question
canadains dont know!
alternator question
Post by canadains dont know! »
hi
im building a sand rail and i installing a new alternator.
there are two connectors on top of this alternator.
MY QUESTION
I NEED TO KNOW WHERE EACH OF THESE ARE CONNECTED TO
im starting from scratch and im doing the wireing my self i have only used generators in the passed.
i cant find any one who knows the answer to this???
HELP!!!!!!!!!
MY E MAIL ADDRESS IS
[email protected]
Post by Marc »
B+ needs to go to the battery and loads (recommend 10GA wire minimum).
D+ goes to the warning lamp, 18GA is adequte. The other side of the warning lamp must have power supplied to it from the ignition switch as in a stock bug - voltage fed to D+ via the filament of the bulb provides the "field flash" to get the alternator going initially.
There's a ground screw on top but it's not vital since the alternator should be well-grounded via the pedestal & strap (don't paint the pedestal saddle)...and if you were relying upon the little 16GA wire usually connected here for a ground you'd have problems anyway, a wire that small couldn't handle the charging current.
Guest
Post by Guest »
THANKS MARC.
WOW THATS GREAT,YOU REALLY SOUND LIKE YOU KNOW WHAT YOUR TALKING ABOUT!
ITS NICE TO GET A STRAIGHT ANSWER
JUST TO GO OVER IT TO MAKE SURE
B GOES TO POSITIVE SIDE OF BATTERY ??
D GOES TO LIGHT AND THEN TO IGNITION SWITCH,SHOULD THAT BE THE START CONNECTION OR THE RUN?
THANKS AGAIN
SCOTT
Post by Marc »
Warning light should be wired to run on ignition switch.
Guest
Post by Guest »
hi again marc
okay ive got it !
thank you
scott
