Opinions needed for 2110 upgrade?
Monkeydub
Post by Monkeydub »
About to collect some parts for my engine upgrade and i need opinions. My current spec in my late bay van (done under 10000):
*Scat forged 82mm chromoly crank
*90.5 B&P Mahle
*Stock ss valve sizes, 3 angle grind, HD springs
*110 engle cam
*40 DRLA's
*SS 4 into 1 1 5/8" header with SS J-tubes and SS turbo muffler
*7.9:1 comp
*standard 1.1:1 rockers on CB bolt up shafts
*Scat i beam rods
This provides really good instant torque but it feels a little out of breath higher up the rpm. I want more power but it's got to be reliable, torquey and a good spread of power... mainly mid-low with a little more top.
The 2 main suggestions I've had are:
1) *Scat Pro street heads 40x35.5 with dual springs (slightly ported)
*c45 cam
*1.25 rockers
2) *Similar heads
*FK 8 cam
*1.4 rockers
I'm considering doing the upgrade myself but have only done top-end rebuilds (stock 1600's)...is this a little too adventurous? Would i also need to replace anything else whilst the case is open e.g cam followers etc???
Thanks....i know it's alot of questions but any help would be great.
Guest
Post by Guest »
I have a 2110 with 40 DRLA w/CB updates an FK7 cam 1.4 rockers
CB ported 40x35.5 heads and the rest about the same as yours,
it has lots of mid-range, good low end pull and revs hard to about
6K. It is a great offroad engine. :wink:
