full flow issues type 3
6T1
I'm having issues with the cooling fan and my full flow fittings what have you guys done to remedy this?
spano
type 3 full flow issue
Hi,
I had the same prob with my type 3 engine after full flowing the case.
I ground down a small amount off the 90 degree fitting and used a die grinder on the fan housing in the corresponding spot. It was fiddly but it now fits fine and bolts up all the way. Hope this helps.
