In the middle of building my 74*94. Got to the point where I need to set the deck height. Due to the longer stroke crank and A Barrels the piston sticks out the top of the barrel by 0.025". I want to set the compression ratio at about 9-9.5 . I figured that if I set the deck height to .045" this will give a compression of 9.3. To get this then I need to space the barrels by .070.
Problem I have is that I can't find .070 spacers. so the questions is can I use 2 spacers to get this height a .040 and a .030 or can I use a .040 spacer and a .030 copper cylinder head Gasket? Do I need to use a head gasket or is it ok to place the head directly on the barrel with no copper gasket?
All help would be greatly appreciated.
Dan
deck height
Either way would work. Personally I wouldn't use head gaskets without a compelling reason (like to make it easy to change the C.R. on a turbo motor). Stacking spacers may not be ideal but I've never had any problems from doing so. I don't think Berg offers any for 94s but they would probably custom-grind some .100s down to .070" for you - for about $60
BTW, I consider .040" to be the bare minimum for a stock bore...IMO .045" is pushing your luck with 94s (it's been done, but I wouldn't go under .050" if this engine is expected to stay together for a long time).
