I want to clone the motor of Mr. Keene, using Renault pieces tu pressurize my 1914 motor with single 32 DIS renault carb.
I was thinking to use my current cam (Engle 110). Is there something wrong with this or is it better an Engle TCS 10? About the turbo I was thinking about using a Garret T2 from a Ford Escort RS Turbo (1600cc). My boost pressure will be around 0.6 bar. The use of my beetle is for daily transportation.
Cam for 1914 turbo
Cam for 1914 turbo
if you are going to use a solex 32 DIS, then i suggest you stick with the stock cam as you will find the carb at 0.6 bar will be too restrictive for much else. As a rule, everything needs to have an equilibrium, therefore, if one part does not match the others, then you will not achieve your goals. The solex is a great carb, but remember it was designed for a 1400cc engine (5) or slowish 1600cc engine (19, Fuego) so if you try to match it to a 1914cc at low boost it will have great bottom end to mid power, but little above 4000 rpm. This would be ideal for a bus, but in a bug it would feel strangled. It would pull up hills though...
One way to make it really perform in a bug would be to up the boost to 15 psi, this would justify a change of cam but would necessitate upgrading other components.
At the end of the day it all boils down to what you aim to achieve...
By the way, the 5 has the T2 and the Fuego/19/Escort share a T3.
matt
[This message has been edited by Matt Keene (edited 05-25-2001).]
matt
