almost ready (long)
almost ready (long)
what ecu are you using to control the fuel and air flow ratios
almost ready (long)
I have been doin' a pan off on my '56 oval and am nearing completion. The trans has been done for a year and the motor is almost ready. Its a 2332 efi turbo,super flows, yada yada. The motor was originally going into a buddy's sand car but i bought it b4 he could finish it. I had to have the intake all redone so the injectors are inboard and it could sneak under the decklid. It uses a chevy truck t. body and ecu. The turbo that he was gonna run is a brand new t4 which is friggin' huge and it looks way too big to fit under the apron. What turbo do you think is small enough to fit under there? I am putting the berg valve cover conversion on tommorrow, then on thurs gonna install it to make sure all fits (and have the header fabricated). I will take lots of pics as it looks pretty one off.
