I currently have Weber 44IDFs on it.
I really like this engine, and still have to do some finishing touches. I do have some questions though, for an engine this size, should I be worrying about the idle jets being 60s? or should I tuned it leaner at idle?
Also, I am thinking baout timing. With the mallory Unilite I can basically tune it however I want, but want to make sure the engine starts right u, and also that the engine doesn't fry and makes the most power as well. Jake, this engine has your 912 special camshaft in it, what total advance and what idle timing should I be looking at? Just curious. This is Jason's old 2270 engine.
With the 12mm motorcycle plugs that are in the heads, what gap should I be running? Specially using the Mallory with the 45,000 coil.
Also, for an engine this size, should I be looking for heavier oil to use? currently using Castrol Syntec 20/50w.
I would love to get these questions answered, for I feel this is the engine that rightfully belongs in the Ghia. (for now )
Jake, if you can send me a PM that would be great. I still want to eventually go with EFI and improve the engine's intake that way.
Sincerely,
Ephry
