chamber cc ??
sixt4vdub
chamber cc ??
Can 45cc be correct for the combustion chamber of a 914 2.0 head??Or am I doing something wrong.
Bugfuel
sixt4vdub wrote:Correct me if I am wrong, You fill chamber up till it is level with the mating surface of the cylinder? Is it ok to use water or not?
use a plastic disc with a couple of holes on it as a cover, make it seal against the cylinder mating surface with a thin coat of vaseline. Then fill the chamber with some suitable liquid: Some use ATF, I prefer water with a LITTLE bit of clothes washing detergent in it. Machine wash detergent won't foam, but it breaks the surface tension that often makes it hard to chase the bubbles out.
Jan
