Any idea if this are/will be available for the T4 setup? Just planning ahead for when I eventually switch to full blown efi.
Cheers,
Sam C
Dont have any copies of VW Trends... Will have to have an ask around and find a copy/get someone to scan it for me.MASSIVE TYPE IV wrote:If you have a July 2001 issue of VW Trends they covered my ignition set up in an article called "Two sparks are better than one"... There are some good pics of the direct ignition parts there..
Cheers,
Sam C
MASSIVE TYPE IV wrote:Samcats engine will make power to 6,500 RPM.
One of the reasons I went with a Mallory, superb bit of kit.MASSIVE TYPE IV wrote:The Mallory is a huge exception to this and they are very accurate compared to any other dizzy- BUT nothing is as accuare as a direct ignition arrangement.
Wow! Thats quite some difference! A flatter torque curve is a VERY nice thing to have, will have the whole driving experience far more fun.MASSIVE TYPE IV wrote: Long story short I have beat the power a Mallory dizzy makes by 8HP+ on a 2270cc engine and if I remember correctly it made 15 lb/ft more torque at peak and aided in creatinga much flatter torque curve..
BUT the mallory is ecellent and cost less than half as much money!
Brian,Beanbooger wrote: Looking at that, I could modify YOUR EXISTING pulley, if you take it off and send it to me. Price would be about $75, complete with the adapter and trigger wheel.
MASSIVE TYPE IV wrote:I have the mounting of the pick up down to a science and have the parts all CNC machined. It looks very cool and fits perfectly on an upright TIV.
You guys seem to overlook the fact that I offer a complete EFI-DFI arrangement for the TIV already... It's a 100% bolt on with the trigger mount AND the modified crank pulley as well as a fuel and ignition MAP already loaded into it... It also includes fuel pump, regulator, throttle bodies and my stainless DTM compatible bellcrank linkage. All you need is fuel hoses.
Sam, I have a fuel/ignition curve for an engine EXACTING your kit. The last guy I uploaded one for was able to install the system and only set his deceleration values, nothing else was touched!
This is why we test things- to remove any and all guesswork.
