Strange transmission??
we got a 73 thing a few months ago and the transmission has real beefy ribs on it.
I searched and didnt find to much.
The code is 081.301.103 2
any help would be great!
Re: Strange transmission??
That is not the trans code. That is the part number of the gear carrier. Go around to the right side just forward of the diff down low. Read the code from under the frame horns. It is stamped into the case about 1.5" below the case part numberWiley e. Coyote wrote: The code is 081.301.103 2
The "boss" has no stamp.Bruce2 wrote:That is not the trans code. That is the part number of the gear carrier. Go around to the right side just forward of the diff down low. Read the code from under the frame horns. It is stamped into the case about 1.5" below the case part numberWiley e. Coyote wrote: The code is 081.301.103 2
I guess thanks anyway?
Bruce2 wrote:Sounds like you have a Rhino case. It is a case made in Brazil with extra ribbing.
I have a hard time logging into this site for some reason.
Anyway Yes it does have extra webbing.
And It is made in brasil.
Next time I get a turn with the digital camera I'll take picture of it.
Wiley e. Coyote
- turboblue
- Muffler Mike
PJMS wrote:Since it is made by VW Brazil, the "081" denotes that is a Brazilian Type 2 transmission case, which would make it a rhino case. There is no ID number because it is a replacement and not a production fitment.
THANK YOU I would go out and look at right now to confirm with pics above...later.
Thank you all for help with a great reference from thesamba!
Wiley E. Coyote
I have a question about these same transmissions is just the case heavier duty but the internals the same as other transmissions or is it a completely different tranny
Well done on using the search!
The trans case indicated above is just a different case that's made in Brazil and has more webbing on the outside.
What's inside is whatever the trans builder put in them. If there's no serial number, it's anyone's guess what is inside. If there is a code stamped onto it, the whole gearbox is likely to have been made in Brazil with all Brazilian parts. Most are interchangeable with German VW trans parts.
