I'm mainly interested in how you solved the gearshift lever from the nosecone.
Thank You.
Herein lies some wisdomThe engine mounts/mounting bar, at the rear of the engine will need to be modified, the engine that I fitted originally came out of a transporter, the bar was shortened so that it could be fitted using the original transporter mounting brackets in place of the rubber type 3/34 engine mounts. This worked fine, but I found that because my car was IRS, the engine was only supported between the gearbox mount at the front, and the engine mounts, practically in the centre of the mounting bar at the rear, this allowed the engine to twist along its axis. I didn't get around to fitting new engine mounts to see if this cured the problem. This shouldn't be a problem with swing axle cars as the gearbox is firmly supported by the chassis. A better alternative, I feel, would be to fit the type 3/34 mounting bar to the engine and keep the existing engine mounts. Although I didn't try this (the mounting bar had already been converted), I'm sure that it could be made to fit.
