Oil Pressure and Connecting Rod Clearances
BajaT4
Post by BajaT4 »
As my engine warms up, I gradually lose oil pressure. At 180 degrees I need to keep the engine above 1000 RPM or the light goes on and the gauge reads about 5 psi. This hasn't always been the case.
Engine is a 2270, DPR crank, CB type 1 H beam rods, Web cam, Raby balanced, etc.
Summer of 2004 my engine developed a knock which ended up being a piston pin too tight which caused the connecting rod to wear .008" into the crankshaft. The rod was also worn about the same .008". I replaced the rod, had Jake rebalance all of the rods and replaced the rod bearings. Rod to crankshaft on 3 of the 4 rods is about .020" and the fourth is .028"
Early 2005, I had a sticking pressure relief plunger problem that resulted in ZERO oil pressure. I cleaned up the plunger seating area with an end mill and shimmed the heck out of the plunger. I did limp home about 5 miles with the OP light :shock: on but do run synthetic oil.
I've got the engine apart now with the intent of putting a full flow setup on it BUT I also need to fix the oil pressure issue. .028" is at the high end for rod endfloat limits. Should I get the crank repaired and will that fix the oil pressure problem or should I be looking somewhere else?
OriginalCustoms
Post by OriginalCustoms »
Another thought is to check the oil pump to case clearances. I've heard of a couple of cases that were too large for the oil pump and resulted in low oil pressure. Just another thought.
Original Customs - top quality automotive service
Sonoma, CA 707-738-5686
BajaT4
Post by BajaT4 »
Good point. Before I took the engine apart, I pulled the pump and checked cover to pump and case to pump clearances. All good.
Post by MASSIVE TYPE IV »
.028 is a bit too open for me... Typicaly my engines run with .018-.020.
I would check the internal oil pump clearances as well.
At this point it's hard to say what the best remedy would be- let me think about it.
BajaT4
Post by BajaT4 »
Actually, I'll be purchasing a new pump from you in the next month so the oil pump won't be a problem!
BajaT4
Post by BajaT4 »
My plan was to get the crank welded locally by a crankshaft shop. As long as they replace material in the groove, balance shouldn't be an issue. With a Raby pump kit, new bearings since the engine is apart anyways and the .008" gap filled, I would think that my oil pressure problem would go away. Those are the only variables that I can see that changed.
I think the crank was modified by DPR originally. I would feel a little more confident in sending the crank to them for repair or do you have anyone else that may be better qualified at this type of repair?
seahag
Post by seahag »
I would suggest returning it to the original maker and let them remedy the problem. After all it is their product.
dstar5000
Post by dstar5000 »
I'm sure DPR would rather you send it to them.
Don
BajaT4
Post by BajaT4 »
Jake do you have contact information for DPR?
Locked
