cam bolts
sgeorgejr
cam bolts
Post by sgeorgejr »
Jake,
i read another post which said not to use washers, however, when i assembled my engine, i did use washers because the cam bolts were hitting the case. I also used blue loctite, should i disassemble and rectify this?
Post by MASSIVE TYPE IV »
What oil pump did you use?
When omitting the washers the cam bolts must be shortened to add clearance between the bolts and the case.
sgeorgejr
Post by sgeorgejr »
the 30 mm shadeck from you guys
jeck
Post by jeck »
I shortened my cam bolts (thread end) on the bench grinder. There were no washers included so I thought that adding them might cause clearance problem. They're already shortened on the head from the T4 store.
What type loctite should I use with them?
"Anybody can sympathize with the sufferings of a friend, but it requires a very fine nature to sympathize with a friend’s success."
-Oscar Wilde
Locked
