I decided on the 60 degree 2.8l Chevy V6. It's a decent size engine and will fit nicely in my '73 Vw Adventurewagen. It makes good power up to 6000 with the cam i chose .....not that i'll be driving there and parts are abundant. I found a cheap doaner S-10 pickup. The engine is carburated and has HEI ignition.I am putting a 350 Holley 2 bbl w/electric choke on it instead of the factory Varajet 2bbl it came with.
Wiring this thing up will be a sinch.... I plan on running a 75amp GM 1 wire alt. to supply the juice for now. Later i'll look into the 105 amp model for more charging power.
I ordered the adapter from Kennedy Engineering to bolt this thing together.
I am going through the engine and freshening it up. The head rebuilds were expensive i thought ... .....needing lot's of work. All the exhaust valves were shot......
I have a friend freshening up the tranny for me. It's a '79 6 rib tranny and he's installing the .77 4th gear to drop my rpms down at highway speed. I figured this tranny with 30" AT tires will drop my rpms to 2600@ 70mph approx. That's good enough for now. The torque of that engine will pull it nicely there. He's a very reputable tranny guy here and he's in my Vw club: http://www.arklatexvwclub.com
This is the look i'm going for......
http://s71.photobucket.com/albums/i160/ ... aja%20Bus/
I am putting the radiator up front. I'm building this camper with a "Baja Bus" offroad look so the brush guard/radiator mount will workout. I'm working on a plan to install a "Mexican Rad Grill" in the brush guard and attempt to make it look good....... We'll see..... I'll probably change the style 4 times before i fire up the torch....
I found a auxilary heater from under the rear seat of a mid 80's Vanagon. It's completely self contained hot water unit with 2 speed Fan,heater core, box and heater valve. I got it for $16.00 at a U-Pullit parts place. It will make a nice aux heater for the conversion....... I'm goin to try find another to build in up front......Easy Defrost.....
Mostly waiting on themachine shop to get the block done , then i'll be real busy for a while........
More to come......
