Pulling Engine - What all should I do??
I will be pulling my motor for the first time to fix a fountain of engine leaks - oil cooler and oil pump - and may replace my push rod tube seals. Any thing else I should fix/inspect while I am in there?
- Type 4 Unleashed
Hey Newbe
You can, if your gonna replace tube seals, do a retorque on the heads, and check the cranks end play. With the pump and cooler re-seal, their's not really much more you can do, without tearing into the motor.
Richard
EMW
EMW
I can think of a couple of things...In addition:
Front pulley (fan) seal
Rear seal (on flywheel) replace is part of checking the end play.
Remove the dist drive shaft first, before puling flywheel. Really.
Consider replacing the trans input shaft bearing in the flywheel, ~$5.
Thick side with the lettering goes OUT.
Clean/lube regardless.
...Clutch/TO beaing time?
Jake gave up his tricks for leak free pushrod tubes--- He uses Permatex Pipe thread sealer.
I polish up and deburr the PR tube bores in the heads with Scotchbrite on a split dowell, chucked up in a drill.
The combination shouldn't cut o-rings on install, or ever leak again.
Another question.. If you are pumping that much oil, how's your blowby?
Another good idea is to install HD 8mm rocker studs/spacers and Porsche adjusters at this time, if you have 8mm adjusters.
The studs/nuts should be done regardless, the factory 7mm step stud/nut is garbage.
It's a PITA to do in the car. (just did it, should've waited until I drop it next month for jugs and heads)
- Dave_Darling
- raygreenwood
Just as Dave and Ray stated, I was referring to crankcase pressure.vesnyderq wrote:Thanks for the input!
Piledriver - You ask about "blowby" - not sure what you are referring to?
You can have a "perfectly" sealed up engine, but if you have tons of blowby from bad rings or loose ex guides, or just inadequate PCV, the oil WILL find a a way out.
