Alternator Question
- sgeorgejr
Alternator Question
When i got my 914, very litttle of the wiring was intact. AS for the alternator, i can see the three prong plug goes to the fuse block, but the single red wire is a mystery. it is too short to go to the starter. Does anyone know where the mystery wire goes?
- Dave_Darling
The thick red wire should go to the starter. Sounds like it got shortened somehow. It should have a ring terminal crimped onto the end, and go onto the same post on the starter solenoid that the really fat cable from the battery (+) post does. It would go up through the engine tin like the other wires do, then back through the rear (vertical) part of the engine tin through a rubber grommet.
Without it, the alternator won't charge anything. BTDT!
--DD
--DD
