Page 9 of 16
Posted: Tue Jun 17, 2008 4:13 pm
by fastmc25
Posted: Tue Jun 17, 2008 9:49 pm
by 55superbeetle
That bus is awsome. Im goin camping this weekend and seeing this really has me thinking
Great job!!!
Posted: Mon Aug 25, 2008 1:24 pm
by fastmc25
Thought i'd pass on some good info.....
Clyde just went on a trip to Eureka Springs, Arkansas for a Vw Campout and Show. Around 411 miles each way.
He pulled the camp trailer i built full of gear up the mountain roads, steep grades and windy switchbacks with no problems.....often never downshifting for the hills.
To go with this he got 19.5 mpg on the trip consistantly going each way.....
Judges frowned on him but other folks loved him..... I had the best sleep i've had in a while while camping in Clyde. The A/C worked well so we slept like babies....
Posted: Mon Aug 25, 2008 5:25 pm
by metropoj
To hell with the judges ! That's awesome .....
Did you get the new grille on yet ?
Posted: Mon Aug 25, 2008 7:35 pm
by fastmc25
Oh yes, I got the grill last week.
I thought i emailed you... sorry......
Were you able to sell your parts? Hope all is well.
Peace,
Posted: Mon Aug 25, 2008 8:24 pm
by metropoj
You did email me, I just forgot if you said you actually installed it on Clyde yet or not ....
Posted: Tue Aug 26, 2008 5:42 am
by fastmc25
I haven't i'm kind of saving it for when i damage the one i have.....
Posted: Wed Aug 27, 2008 7:10 am
by superwrench73
What kind of A/C are you running? It cracks me up when people frown upon our type of conversion. Why don't they frown on the fact that the bus was turned into a camper to begin with by a conversion company? If everyone left their rides stock, it would be a boring world. Awesome trailer!
Posted: Wed Aug 27, 2008 5:19 pm
by fastmc25
Posted: Wed Sep 03, 2008 5:34 pm
by fastmc25
Since my Bay is converted to a watercooled V6 and with winter approaching i needed to come up with a viable heat solution..... I got a rear auxilary heater from a Vanagon. It is a fully self contained heat unit with Heater core, 3 speed fan and a water valve....
I built a console / box that fits between the front seats in the walk through area of my bus. When installed i'll run 2- 3/4" braided hoses from the engine through the heat tube in the center of the bus. .....
This will supply good low-high heat to the front floor area..... The fan blows strong on Med and stronger on high.....
Now for down here in the south this will be sufficient heating for a driver and front passennger..... I'm still working on a defrost adapter for the unit that will utilize the original defrost vents in the dash....
If nothing else it's an idea you can work from..... I notice we never address the heating after we convert our cars.... at least not much....
Posted: Fri Sep 05, 2008 11:20 am
by WestyPop
Clyde's lookin' good, Paul.
Are you going to utilize 'the tree' in your defroster plumbing, or did that disappear with the mods for the radiator up front?
Personally, I'm trying to figure out how to keep & use 'the tree', possibly even utilizing it for heat distribution rearward while on the road. My Westy's 'tree' can stay intact since its radiator will be all mounted out front, not the slick integrated Mexi-Brasilian style as on Clyde.
The overall size of that rear Vanagon heater module is pretty nice; hadn't noticed those before. And it looks like your cabinetry is top notch. Thanks for the info & pics.
J.R.
68 Westy
(+ others)
Posted: Fri Sep 05, 2008 12:43 pm
by fastmc25
Hey J.R., Thanks,
I actually didn't loose the top of the tree...... I also retained almost all of my airbox up front...... as well as all defrost ductwork..
I didn't want to loose the fresh air available up front...... I am actually going to make a defrost adapter that will attach the heater to the tree when i need it..... It will be functional to say the least....
More to come....
Now i need about 20' of braided steel water lines to run to the motor.....
Posted: Fri Sep 05, 2008 12:55 pm
by fastmc25
Here is a extra heater for sale right now on Samba...
http://www.thesamba.com:80/vw/classifie ... ?id=624143
The original plan was to mount this in the rear under the bed and duct it through the original center tube to the front like original..... The original dash cables to the rear can be modified to operate the temp... Then the system will reheat interior air and be controlled from the front like original......
But i got lazy.....
Posted: Sun Sep 07, 2008 3:00 pm
by WestyPop
Thanks for the tip on the rear V'gon heater, Paul. As to the 20' of heater hose, what about running the major lengths in schedule 80 PVC, protected by the foam insulating outer covers. When my '68 Westy gets to that more-or-less finished stage, it's gonna get re-undercoated anyway, maybe even get sprayed with bedliner first. Seems like that would be fairly protected. The ends could easily be s.s. braid-covered flex lines.
As far as the A/C goes, I've got an under-dash unit(VPC?) and the Sanden compressor/bracketry/pulleys for the 2.8L V6. OTOH it doesn't seem like that will do much of a job at cooling down the rear/camper section of the Westy while on the road, so a clever & compact rear evaporator/fan/distribution box needs to get designed & fabbed.
Kinda thinking about something that might output toward the middle of the bus, but have its pre-evaporator intake near the rear; y'know recirculated A/C. Since the '68 Westy has the full height closet/cabinet on the right hand side, it might even be possible to put most of such a rear distribution system along the otherwise largely-wasted space on top of that, even running the refrigerant plumbing up inside, alongside the closet door.
Just some ideas at this point, but necessary to get the entire family camping from Spring to Fall. I really appreciate seeing your excellent work. Don't say "lazy"; it's "prioritized expediency"!
J.R.
68 Westy
(+ others)
Posted: Sun Sep 07, 2008 3:17 pm
by fastmc25
Thanks,
I sometimes tend to over engineer my projects as i usually try and foresee any possible failure..
... that's why all the S.S. braided hose..... I don't like walking......
I actually have a underdash unit and i plan on install it sometime....
. I have all the bracketry for my engine and a evaporator. I just need to get the lines made and buy the compressor......
