Posted: Mon Apr 12, 2004 7:06 pm
Could you elaborate?JohnConnolly wrote:I do the cam break in and ring break in at the same time.
john
Aircooled.Net Inc.
Thanks,
Andy
john
Aircooled.Net Inc.
It's cheaper at the grocery store - look for the green can labeled "Comet".Honda's Killer wrote:What about that "ring seal" Total Seal makes?
You are so right Marc.Marc wrote::
I always specified that sustained high speed driving should be avoided for the first three hundred miles - stay off the freeway if you have a choice, but if you must drive any significant distance vary your speed as much as practical. At 300 miles an oil change, valve adjustment and inspection were mandatory for warranty coverage.
Bruce I work with lots of European manufacturers, all the ones I have worked at have both hot tested there engines and tested the cars. (I do diesel engine management btwBruce2 wrote:.
I remember reading about manufacturing techniques, and one example was Toyota. They have their assembly procedures and quality so well controlled that when the car is finished assembly, they don't even start the cars before shipping them out. There's no need to test them, they know they will all work. Now Toyota is not Nissan, but I find it very hard to believe that Nissan would spend such a phenomenal amount of time (3min) on every car when Toyota doesn't.
When I toured VW in Wolfsburg, they just drive the cars off the line, no dynos. I figure when you are building cars at 4000 per day, you can't spend that much time on every car.
However, at Karmann, they had a couple of dyno cells in the middle of the factory floor. We watched one car for 3-4 minutes. I wasn't there long enough to determine if every car went through this, or just the nth car.
