Page 4 of 5
Posted: Fri Jan 09, 2009 8:58 am
by AMBROSIA
just received the post, thanks mate, i owe you
No worries :D
Are you using stock 1.9 bolts then?
I'll check the workshop manual when I get home.
Posted: Fri Jan 09, 2009 1:59 pm
by Stephanhipwell
yeah :wink:
Posted: Tue Jan 13, 2009 2:15 pm
by AMBROSIA
Sorry for the delay about the rod bolts.
The manual say's 45nm (33 ft lb) for pre 86, 22 ft lb + half turn for post 86.
Iain.
Posted: Tue Jan 13, 2009 3:03 pm
by Stephanhipwell
great, is that the vanagon workshop manual?
how can i find out how old the engine is? i have the case number, and it has the later stat.
Posted: Wed Jan 14, 2009 8:19 am
by AMBROSIA
I would guess the difference is actually between stretch and non stretch bolts rather than the engine age.
It is a workshop manual in pdf format.
Got mine off ebay for £5 some while back.
Iain.
Posted: Wed Jan 14, 2009 11:05 am
by Stephanhipwell
coolio, i'll go with the early setting then.
cleaned valves and a bit of heads, hopefully finish em and do some lapping. also where the gaskets fit need a skim as they have some pitting.
Posted: Wed Jan 14, 2009 6:19 pm
by tencentlife
The stretch rod bolts have a threaded portion about 22mm long. Do not use these bolts, at all, not new and especially not reused.
The "solid" or 1.9 bolts have threads about 13mm long. These are OK to reuse, torque to 45Nm (33ft.lb.).
Posted: Thu Jan 15, 2009 3:03 am
by Stephanhipwell
tencentlife wrote:The stretch rod bolts have a threaded portion about 22mm long. Do not use these bolts, at all, not new and especially not reused.
yeah these are the ones i have. thanks :)
Posted: Thu Jan 15, 2009 5:47 am
by AMBROSIA
How much are you intending to 'skim' off the heads?
You can't take too much off of they won't seal properly.
I had a badly corroded head years ago that I had sand blasted and then I filled it with liquid metal. Carried on sealing for years afterwards.
Posted: Thu Jan 15, 2009 10:15 am
by Stephanhipwell
was gonna do the liquid metal thing :D
Posted: Fri Jan 16, 2009 5:19 am
by AMBROSIA
I have a couple of spare heads that have some bad pitting.
If I ever get some spare time I will get them sandblasted to see how bad they actually are.
I was tempted to get them welded but from what I gather the quality of the original heads are not that great with plenty of impurities.
Posted: Wed Feb 18, 2009 8:24 am
by Stephanhipwell
finnaly putting heads together today and found a split in one of the pushrods, anybody have one spare or know where i can get a single one as opposed to a whole set?
Posted: Wed Feb 18, 2009 12:53 pm
by AMBROSIA
You mean pushrod tubes or the pushrods?
You can get single pushrod tubes from gsf.
I've used a set of CSP spring loaded ones from machine 7 as they can be resealed without removing the heads.
Not cheap but seriously good quality.
http://www.machine7.com/product.php?xProd=227
Posted: Wed Feb 18, 2009 1:33 pm
by Stephanhipwell
AMBROSIA wrote:You mean pushrod tubes or the pushrods?
i've been told that they leak, have you had any problems?
Posted: Wed Feb 18, 2009 3:45 pm
by fastback
http://www.thesamba.com/vw/classifieds/ ... ?id=516068
i use these on my engines.
stainless steel and double o-ring's.
do not leak
