Where Did You Start?
Click a link below
Man this is one Awesome Detailed Engine Build
Here's another one thanks to Terry Cloyd for saving it.
Thanks goes to Jim Martin for this one
Thanks Marty for these two.
BIG DADDY
Norwegian Pro Mod motor
Thanks Sanddude for this one.
SandDude's 2332 build
044 Ultra Magnum Plus
48IDF vs. 48IDA
84mm crank with 5.4 inch rods
90.5 vs 92
90.5 and 94
94's that fit 90.5 holes.
94 or 90.5
94mm to 90.5mm
225lbs of comp.
2110 Compression Ratio Suggestions
Aftermarket cases.
AfterMarket Heads
Anyone actually Use 87mm slip in’s? Are they REALLY that bad?
Any Way To Put Type 4 Head on Type 1 Engine?
Anodized Aluminum Engine
Airplane Fuel
Berg cranks...worth the money?
Berg Mounts
Balancing pistons
Bugpack St. Pro vs C B 044\'s
CB Performance Uni -Tech rods
Cam Gear Bolts to Oil Pump Clearance
Cams vs. Compression
Case Sealent
Cast crank from SCAT
Cast vs Forged Crankshafts
CB's CNC heads
CB's rear disc brake!
Choosing a 78mm crank
Choosing a Tranny
Chromoly Push Rods Don’t Expand?!
Clearance
CNC ported heads good product?
Compression ratios & altitude
Compression Ratio explained by Scott The Viking
Cylinder Sealer
Deck Height, How much is Too Much
Distributors
Dual Carb Kits.
First time porting intakes, help
Flanged Crank Endplay
Flywheel weight
Freezing Parts
Gene Berg engines
Great gasket sealer
Harney's diatribe - rocker geometry to install & beyond
Head porters
Heads and Cams
Head temp gauge
Heads, valves, springs, cams?????
"How to port your own heads"
HPC Ceramic Coating for headers
Is 10:1 compression to much?
John C's Supersquish PistonsLobe centers
New TI case (Aluminum)
NITROUS
OIL PRESSURE
Oil Temp Sensors
Porting Heads
Pre Oiling
Raising compression
Rev Limiters?
ROD RATIO ??
Rod Ratio/Cam choice
Sealing an Engine Case?
Slicks
Square" Motors? good idea? 88X88 90X90.5? advantages?
Scat Killer Case?
Scat Pro Comp rockers
So Who makes a good Crank?
Speed secrets of the day
Stroking an Engine
SuperFlo II Heads On Street
The Rotating Mass
The Thing About Lobe Centers.
THREE LITRE STREET MOTORS!!
Transmission Relocation
Type 1 vs. Type 4
Type 1 vs. Type 4
Type 1 vs. Type 4
Type-IV oil cooler conversion
Type 4 cooler conversion
T4 oil cooler into T1instructions?
Wasserboxer cranks in type
What compression ratio?
What is so great about a Type IV Engine?
What makes a good head.
What type case is best?
Why I think 2275cc is the best Value
Zero Valve Lash
Hotbugsy
Post by Hotbugsy »
Stick that post at the TOP of the list !!
Tom Notch
Post by Tom Notch »
A most excellent list!
Now maybe a better name for this treasure?
Tom
Tom's Old VW Home
DVKK
DSD, dark side disciples
Tom Notch wrote:A most excellent list!
Tom thanks, your the Moderater change it to whatever you want.
Tom Notch
Post by Tom Notch »
oh, no, can't pull that power trip stuff on me :wink:
I'm just here to delete the porn :roll:
It's You Guy's Forum!
How about the "Super Sticky"?
I just glanced at some posts from 4-5 years ago, some stuff needs updated!
Tom
Tom's Old VW Home
DVKK
98% of it is from page 230-290. I thought it would be good to hash some of this over again.
doc
Site Admin
Post by doc »
Nice effort here. Keep it up. :D
I read several of these last night. Some are among the very first posts on STF. Pretty interesting stuff.
doc
terry cloyd
Post by terry cloyd »
Thanks David. I would like to take the credit for this, however Jim Martin is the one that put it together. I found the information on another Forum, and thought it would be helpful here. I was surprised at how much time he has put into giving this information to everyone else. He has done a much better job of sharing his knowledge about the VW motor than any of the other VW builders I have known. So, thanks to Jim for sharing. terry
terry cloyd wrote:Thanks David. I would like to take the credit for this, however Jim Martin is the one that put it together. I found the information on another Forum, and thought it would be helpful here. I was surprised at how much time he has put into giving this information to everyone else. He has done a much better job of sharing his knowledge about the VW motor than any of the other VW builders I have known. So, thanks to Jim for sharing. terry
And thanks Terry for saving it.
Chaos
Post by Chaos »
Awesome list and tips.
Thanks for setting this up
allenparker
Post by allenparker »
The links on this list no longer work. Can anyone fix this?
allenparker wrote:The links on this list no longer work. Can anyone fix this?
For now you have to change the .com to .net we are changing servers.
AnticGod
Re: Where Did You Start?
Post by AnticGod »
Excelent list dude! Thanks for sharing it! :)
I have visited a lot of these today... :)
