Accu-Fire?
Posted: Thu Jun 19, 2003 5:24 pm
by MrBreeze.Com
Has anyone ever tried the Empi Accu-Fire ignition? Also, what's the difference between Suppressed and Copper Core Non-Suppressed wires?
-=Rob
77 Westy
Posted: Thu Jun 19, 2003 6:28 pm
by raygreenwood
Don't know on the ignition...but copper core wires are usually wound with glass, aramid or some other highly insulative wire, then covered with silicon. They are standard type VW wires. The others are radio suppresion wires. Many have a carbon strand core which concducts well and leaks less intereference to your radio. The copper cores generally have the proper resistance for thestock VW ignition and are much more durable in these cars. Ray
Posted: Thu Jun 19, 2003 8:19 pm
by Marc
Posted: Thu Jun 19, 2003 10:22 pm
by westy78
For you guys running the Pertronix module. What is your dwell reading at? With mine the dwell is 42 degrees. That is with a new Bosch blue coil. I've heard that increasing the gap of the module wont change the dwell. Do I have a bad module? Its in a stock dizzy in a '78 Westy.
Posted: Mon Jun 23, 2003 7:16 am
by Elrick
I too am interested in this dwell Pertonix topic.
Posted: Mon Jun 23, 2003 9:17 am
by westy78
Here's an update to my question. I tried different air gaps with the module from right up on the magnet to far away. When it was the farthest from the magnet the dwell went down to about 39-40 degrees. With the module closest to the magnet it went back to 42. I then reset it to where it was suppose to be and it dropped to 38. I had enough and went and bought a new module. Installed it at the correct air gap with the little plastic piece they give you and now the dwell sits right at 50 degrees with a rock solid timing. Perfect! Guess I had a bad module.
Posted: Mon Jun 23, 2003 11:44 am
by Guest
if you send in the old one, they will send you a replacement.
also for anybody interested, I saw that Moores parts had the compufire on sale on their website
