Ignition Problem? Help!
Posted: Mon Aug 25, 2003 2:19 pm
i was cruising down the highway a couple of days ago, engine mildly loaded, running great and i get a miss, gradual at first and then it just progressively gets worse. Right now the engine will fire right up, it will give 3 or 4 good revs, sounds great, then on about the fifth rev it will start cutting out, then if you hold the throttle at like 2-3k it will only run on one or two cylinders. If you shut if off for a few minuites it will do the exact same thing, doesnt matter if the engine is cold or hot. I can not isolate it being on either bank of cyls. I pulled carbs, took them apart, blew everything out, they were very clean. I checked flow of fuel to carbs, both sides, good strong pumps when cranking. Carburation doesnt really make sense since if the engine sits for a little while it will run strong initially, i also changed all the plugs. I am assuming it must be my compufire or my coil, or possibly a resistor in a plug wire? any thoughts?
