Page 1 of 4
Kit Carlsen FI
Posted: Fri Aug 13, 2004 10:16 am
by michaelmoo
Will the KCFI have the look of the factory system. Just curious. Just thought it would be neat to make it look like a stock 914 engine but it runs like a ?6!!
Michael Moore (the non fat one)
Posted: Fri Aug 13, 2004 11:11 am
by MASSIVE TYPE IV
It absolutely can, according to tune of the engine and cooling system choice
we are making a Plenum that will use standard 2.0 runners that are shortened and allow up to a 75mm throttle body to be used, or stock. It will be fiberglass so just cut the holes you want and go from there!
My system on the 912E looks 100% stock unil you see the serial cable protruding from the stock brain box! Mine was a custom job that Dave did for me, so if you want it to look that stealth you may need to do some of the work yourself..
Posted: Tue Aug 17, 2004 2:53 pm
by Ephry73
Jake, any pics of the setup?
I have been looking at the new website, and it looks good.
The single plenum EFI for use with the DTM would be a good thing, specially if one wants to add a little turbo to the works.
Any more info on the KCFI?
Thanks,
Ephry
Posted: Tue Aug 17, 2004 3:11 pm
by MASSIVE TYPE IV
Its being tested every day. I put 400 miles on it over the weekend...
My set up looks 100% factory, just visualize that and you don't need any pics..
Total stealth till you see the laptop. When the laptop is disconnected no one would know its there.
Posted: Tue Aug 17, 2004 3:21 pm
by Ephry73
Hmmm, wonder what the cost for that system would be. Any testing soon on a turbo? need a guiney pig?
E
Posted: Tue Aug 17, 2004 3:25 pm
by MASSIVE TYPE IV
The other system being tested is in a Turbo 914.
Trust, me I have received hundreds of emails on this system. Many of them I have not answered simply because we lack data, and we also lack product to sell.
This will be the ONLY EMS designed by a VW person, for a VW aircooled application, and it will come as a 100% ready to go kit set up for the engine that you will be installing it onto. I also plan on selling one version of it that is the brain and electronics only, but if you choose to go that way, don't ask me for any assistance!
Posted: Tue Aug 17, 2004 4:44 pm
by Ephry73
He he. I hear ya Jake. Well it sounds like once you guys get all the data I will be able to use a Turbo with an EFi system and a DTM shroud
Thanks a again
E
KC EMS
Posted: Fri Aug 20, 2004 1:13 pm
by KitCarlson
All,
Sorry, I have been offline and out of touch.
I am working to put the EMS in production.
It will be sold initially through Jake and Brad Mayeur.
Wholesale price $1K, includes: quad coil, tps, distributor assembly, harness. Core charge on distributor $40. Installation not included.
Two harness styles DTM IR Type 4, and 914.
Time to market < 8 weeks, I hope.
Kit
Posted: Fri Aug 20, 2004 1:24 pm
by MASSIVE TYPE IV
SWEET!
Posted: Fri Aug 20, 2004 1:35 pm
by Guest
OH Boy now what do I do with my 45 Dells
Posted: Fri Aug 20, 2004 1:36 pm
by Guest
Dave, I bought an old
Dell Latitude CPi D233ST laptop to (hopefully) program your EMS. You mentioned that I should look for a laptop with a RS232 port but I don't think this laptop has one so do I have to buy some kind of cable that will adapt the laptop's USB 1.0 port to RS232?
by Guest
by Guest
Posted: Fri Aug 20, 2004 3:03 pm
by Greggyboy
Yes they make USB to RS 232 adapters but you dont need one, you should have 2 SERIAL connectors on the back. They are 9 pin D connectors. A serial interface is the same as an RS232.
Posted: Fri Aug 20, 2004 3:57 pm
by Guest
Greggyboy wrote:Yes they make USB to RS 232 adapters but you dont need one, you should have 2 SERIAL connectors on the back. They are 9 pin D connectors. A serial interface is the same as an RS232.
Thanks for clearing that up.
